[ROM][EE4] GummyCHARGED 1.8 6/22/2011
kejar31
Active member
Dec 30, 2010
36
32
Gummy CHARGED
Rev your Charge up and get ready cause this things fast!!!
Notes:
Select Settings-->Display settings-->Unlock screen-->Glass unlock to get incoming calls to show up with the AOSP lockscreen slider rather than the puzzle crap
* If coming from another ROM You MUST wipe before installing this
* The first boot after install GummyCharged will take a while at both the Samsung logo and the bootsplash. Give it a couple of minutes
*** Choose your own Gummy Flavor --- see third Post on RootzWiki to download GummyThemes
TeamGummy
Primary Dev and Themer - Kejar31
Official Tester - papi92
FABOLOUS for allowing me to use his Server to host Gummy Charged and letting me use his toolbox script to make mine!!! :)
Thanks to Teamdouche for publicly posting the CM source, which I compiled some of my apps from.
DroidXcon for his help and patience with me while walking me thought the while Odin thing
Credits:
IMNUTS ? His initial ed2 Debloated ROM was where I started on GummyCharged 1.0 (although GummyCharged 1.5 has a completely new base)
Features:
- Most all apps were built from source.... rather that decompiled and hacked apps via APKmanager!!!!! To do this I took the CM and Android source trees from Froyo and reworked the framework to allow apps to properly find resources after they were compiled.
- New Base built on top of EE4
- The only apps left from TW are Dialer, Contacts, Camera and Browser
- AppWidgetPicker - built byboombuler
- Latest Market included
- Black Gtalk ? themed by me
- Ads blocked via hosts file -thanks to delta_foxtrot2
- 1% battery increments built in (Icons made by me)
- Themed Dialer, Contacts, Keyboard Task Manager by me to integrate into the stock GB look and feel
- All apps optimized and zip aligned
More to come...
Known Issues:
- There are still some themes tweaks that need to be done but for the most part you will most likely not even notice.. Expect them to be resolve in a future release
- Some people are having issues with Exchange and may continue to do so until I get a chance to look into it
Disclaimer:
I take no responsibility for what this ROM may do to your phone.
Download:
RootzWiki
Updates:
Change Log:
1.7.5
-Finished the Theme (if you see a bug let me know)
*Remeoved the location icon
*Fixxed black on black text in many places thoughout
*Fixed white on white text when adding a contact
*removed the batter charged (credit imnuts)
*tweaked TW apps for an overall better more integrated look
-Removed
*MusicMoc (CM6's Music Player)
*Media Hub
*DLNA
*CM6's Filemanager
*CM6's Email app (was causing issues with Exchange)
-Added
*Google's Music player (the one used with Music Beta)
*CM7's Files-manager (compiled myself)
*Email app built from AOSP (fixes Exchange and other issues)
*Terminal Emulator
*Gummy Toolbox*******
-Fixed
*Email issues
*FC on contact deletes
*USB automounting (credit imnuts)
-Toolbox
*To access open Terminal Emulator and type $su the #gummytoolbox
*The toolbox will allow you to add back apps such as MediaHub, DLNA, MusicMod and VVM
*Much more to com from the toolbox down the road :)
*Remove and add Adblocking
1.8
-Tweaked Theme
*Dialer tab tweak - creadit thefunkbot
*Fixed landscape dialer theme
*Cleaned up the Phone incall theme
-Removed
*TW VideoPlayer
*misc uneeded apk's in the apps folder
-Updated/Fixed
*Gallery3D - fixed sensor leak and video playback
*Contacts - fixed FC on delete properly this time
*Calendar - fix FC on access Calendars
*Terminal Emulator - updated to the one built in CM6
-Added
*Imoseyon Tweaks - sysctl, SD card read ahead, swap file
-Toolbox updates
*Added TW Calculator to the install options
*Added TW VideoPlayer to the install options
Install:
make sure you have root and Clockwork recovery installed
-boot into recovery via Recovery
-select "wipe data/factory reset"
-select "Yes -- delete all data"
-go back
-select "install zip from sdcard"
-select "choose zip from sdcard"
-find and select GummyChargedXX.zip
-reboot
Install Themes:
-find and select GummyXthemeX.zip
-reboot
Accessing the Toolbox:
-Open Term
-Type "su" (give root permissions if asked)
-Type "gummytoolbox"
Update Toolbox:
-Open Term
-Type "updatetb"
Twitter:
Follow me on Twitter for Extra news and updates on GummyCharged @kejar31
Donate:
Donate if you like what we do by buying us a round of beers!
kejar31
Active member
Dec 30, 2010
36
32
ScreenShots
saillling4life
226
4
Thanks a ton! I heard this was going to be great. And when you where talking about what to download, are all the files in GummyCharged1.0 or are they seperate from GummyCharged1.0, if they are seperate, could I have the link please.
DroidXcon
11,102
3,392
Guys this is a solid rom i suggest you give it a try. i have been running it for about 20hrs with no problems, and battery life should not be effected at all.
Thanks to Kejar for contributing im sure everyone agrees that its nice to have more options
brianct1972
158
3
I am still really enjoying yours though!! I hope you continue to update it.
tsitalon1
Active member
Apr 22, 2011
42
Just checking..... If running altered beast, do i just wipe and flash over using ClockworkMod?
No harm to voodoo and ext 4.right?
If i want to go back to AB, do i just wipe and reflash with odin?
Raptor007
Trusted Member
Apr 18, 2010
4,906
58
Right now I am on Altered Beast which is a great ROM, I am d/l GummyCHARGED right now. What is the best way to get GummyCHARGED installed. I noticed kejar31 said:
-go back
-reboot
Should I just flash the Rooted Stock ED1 image via Odin then flash CWM and then the ROM and finally Voodoo Kernel Lagfix?
Will you be offering a kernel later on that will support OC/UV and Voodoo Lagfix?
kejar31
Active member
Dec 30, 2010
36
32
-go back
-reboot
No need for the voodo Kernel (thats up to you but you will need Clock work recovery
DroidXcon
11,102
3,392
-go back
-reboot
If you are going to flash ED1 don't forget to disable lagfix
Sent from my SCH-I510 using Tapatalk
elucid
Active member
May 31, 2011
37
Droidxcon, I'm using your rom and am liking it. How would you compare this rom to yours in terms of battery life, speed, free memory, etc. Is this further debloated?
offroadr35
got access to a PC to install CWM, now a new problem.
When I wipe data using CWM, it seems to hang on "Formatting /sdcard/.android_secure..." It's been there for at least 5 minutes. Suggestions?
Thanks,
Steve
kejar31
Active member
Dec 30, 2010
36
32
Thanks for the heads up. Why no Voodoo Kernel, is this fast enough that the lagfix is no longer needed?
I didnt include a Kernel cause I don't want people worrying about the voodo fix.. This ROM will work whether you have it or not.. I left the kernel up to the user.
DroidXcon
11,102
3,392
It seems about the same speedwise and battery life, but his rom has a more unified theme to it ,and cleaner look than mine. And im sure he is going to come out with some great updates as he is alot more experienced than i am :)
kejar31
Active member
Dec 30, 2010
36
32
OK for people having issues with some videos and Quadrant I posted a fix under updates in the OP.. Just install the update in CWM
Raptor007
Trusted Member
Apr 18, 2010
4,906
58
Thanks,
Steve
You are using the CWM that was a test build, imnuts is still working on the format issue. You should use the original CWM imnuts came up with in the Voodoo Kernel thread here [ROOT] [KERNEL] [RECOVERY] - Root / Voodoo Lagfix / CWM Recovery - xda-developers this one does work in terms of format.
fallingOutOfLoveWfithTech
