So if running ab4.1.1 i cant just simply wipe and install from zip?
I need to do all those steps going to ed1 OTA Ed2 OTA EE4 then cwr and install gummy from zip?
What do i do w vodoo lagfix?
Will i lose root/su?
How do I get visual voicemail on this?
Really fast.
Issue 1.) on AB V4.1.1 if you hit the menu button on the home screen "preferences" pops up as well as settings. Preferences allows you to go in and modify your settings for launcher pro (and plus if you have it). Your mod seems to be missing that which won't allow me to stop the 3D experimental app drawer.
If you could update that or let me know how to get launcher pro preferences back please let me know..
otherwise great work.
I asked the same ? then discovered this is the AOSP launcher from XDA not LP. Looks very close. So you can disable the AOSP launcher once you have LP or leave it in the background with no widgets and switch to LP
I apologize if this has been asked, but I've been searching on forums and have yet to see the answer I'm looking for. I've installed Gummy, but I keep getting a force close on the standard email. I see a fix for it...but can someone please tell me EXACTLY how to install the fix? Do I unzip it ot leave it zipped. Flash with Odin or CWM. Or if I completely reinstall Gummy, should it be fixed. Please help.
Thanks.
So stupid question here, how do I get my phone to boot into recovery on this ROM? Tried usual method of volume, home and power but didnt work.
I haven't seen it mentioned yet but others having MMS force close when you get a picture msg. I just flashed yesterday and got the first one since then and did not realize it Fc's when you try to view the pic.
Odd, that is how it should boot in CWM. You can also try one of the reboot apps in the market.
yea I wasn't aware of it either.. That is until today... Looking into it and will post a fix if and when I find one.
any one of those you would recommend?
Install the Email Exchange fix just like you did the ROM though CWR but don't wipe data.. You did wipe data before installing Gummy, right... Cause if you didn't that could cause some of the FC's you are seeing.
Eitherway install the email fix and let me know if it works for ya.
