1. chopstix9's Avatar
    Was running stock rooted Ed1 Rooted with Gingersnap. Took update to ED2 and lost root. Tried to root again with Gingersnap didn't take. Went back into phone via odin to roll back to ED1 and while it was connected and in process, cat jumped onto desk and bumped phone and it lost USB connection.
    Got FAIL in Odin. Put battery in phone and just get yellow droid - ! - computer image.
    Now in Odin trying to roll back and it is just sitting at Initialzation.
    WHAT CAN I DO ?!!!
    Really need this phone for work tomorrow ...
    Any help GREATLY appreciated.
    Steve
    06-09-2011 07:46 PM
  2. gunnermike53's Avatar
    you sir have got yourself a brick. congradulations.
    make sure you are using the original usb cable. if you are on a laptop make sure your power settings are set to high performance.
    try to odin to ed1 again.
    06-09-2011 08:31 PM
  3. chopstix9's Avatar
    thanx man ... all set here got it with help from over @ xda ... was in panic mode !! appreciate the reply
    06-09-2011 08:44 PM
  4. elucid's Avatar
    Whew
    Sent from my SCH-I510 using Tapatalk
    06-09-2011 09:23 PM
