1. Veregund's Avatar
    Hey guys-
    I was wondering if there are different sets of drivers for the charge - 32bit and 64bit. I'm asking because I can't seem to get my phone into mass storage mode when i connect it to my computer (the option doesnt even pop up on my phone), and I figured it might be a driver issue. If there are different sets of drivers, can someone link the 64bit version? thanks
    06-17-2011 06:14 AM
  2. Aixelsyd's Avatar
    Not that I am aware of. I run Win 7 64bit and used the drivers that are linked in a few of the ROM thread and have no issue. That said what ROM are you running? Reason being is there is a few that were out originally that needed to have a fix done so the sdcard would mount correctly when hooked up to your computer.
    06-17-2011 07:25 AM
  3. chadness's Avatar
    06-17-2011 09:27 AM
  4. Veregund's Avatar
    1.) I'm not running any particular ROM. I have inmuts CWM flashed and voodoo lagfix.
    2.) I can't put that sdcard fix on my sd card, since I cant enable storage when connecting the phone to my comp lol
    06-17-2011 04:57 PM
  5. Aixelsyd's Avatar
    Download the file right on your phone. Shouldn't need your comp to get it. then run the file like the O of the link says and you should be good to go.
    06-18-2011 08:44 AM
