1. Scrapper's Avatar
    I just rooted my EE4 phone with CWM, Imnuts PBJ with voodoo and the sd card patch, every thing went ok and seemed to be working except my computer couldn't find the sd card. I turned the phone off and then back on. It gets to the lock screen and then I get sorry process stopped on my launcher pro and other apps installed and it wont let me past the lock screen. I have pulled the battery, tried booting from recovery and it still does the same thing. Any ideas how I get past this? At this point the computer doesnt reconize that the phone is attached should I do a system reset from the recovery boot menu? Any help would be greatly appreciated.
    06-19-2011 02:34 PM
