1. antbrax11's Avatar
    I really need some help. I have the Verizon Droid Charge running Gummy, voodoo and overclock. I can connect with wifi_tether 3.0 and PdaNet but the internet connection get's lost in 5-10 minutes. I've tried Barnacle and just about every setting. Please help if you've been able to get either to run or if you have any ideas....
    06-27-2011 09:49 PM
  2. zman6900's Avatar
    It's a problem with the network. Can't say for what but Ad-hoc could be a contributor to the problem. VZ probably momentarily times out a connection is they see it being use frequently. I know I would if I was a greedy corporation. If you want to be able to complain, buy it and then b!tch to VZ - maybe they'll give you a month free. They did me.
    06-27-2011 11:42 PM
  3. antbrax11's Avatar
    Thanks but I would like a more permanent fix at no $$.
    06-28-2011 01:25 PM
  4. zman6900's Avatar
    same here. when you find one, let me know.
    06-28-2011 02:12 PM
Tags for this Thread
