11-11-2013 11:47 PM
40 12
tools
  1. goliatham's Avatar
    My maxx is rooted, and I applied the update today.
    My phone is now rebooting constantly. It loads and I can navigate around for about 30 seconds, then it powers down and boots up again. repeat, repeat repeat.
    It figures...This was the first time I applied an update on a device without either unrooting, or waiting to see how the update was impacting people.
    Any other rooted users having this issue?
    11-05-2013 06:32 AM
  2. SeigaGen's Avatar
    I don't think the update will apply on a rooted phone. I'm not sure if u will be able to apply the update at this time. You will have to perform a factory reset and wait for the update on official release. Go into fast boot mode (vol down + power key) after the phone restarts and perform a reset.
    Sent from my XT1080M (Droid Maxx) using Tapatalk 4 Pro
    11-05-2013 07:07 AM
  3. goliatham's Avatar
    I thought I was clear. I did get the update, and applied it, AND I'm stuck in a power cycle loop.
    The private soak test forums already have 4 rooted users reporting same issue. Rooted (AND even unrooted/derooted) users probably don't want to apply this update.
    Selecting any option in recovery also just boots the phone.
    11-05-2013 07:15 AM
  4. SteelGator's Avatar
    Not to be an ***, but shouldn't this conversation be taking place in the private forums and not here?
    Sent from my XT1080 using Tapatalk
    jesta192 and Westiemom like this.
    11-05-2013 07:36 AM
  5. 18t's Avatar
    Rule one for being rooted: never ever ever ever ever ever ever accept a OEM update if you plan to keep root/functioning phone. Even the root creator told you not to do it.
    You'll probably have better luck fixing it on xda than you will here. If you can.
    Ry, KWKSLVR, JimBen73 and 1 others like this.
    11-05-2013 08:02 AM
  6. goliatham's Avatar
    Yeah, I opened it up here before remembering about those forums. I still think it's a worthwhile warning to people who may not check those forums until after they have a problem.
    I was OK with losing root, this went a bit beyond that though. XDA is next step if Motorola's private forums don't help out.
    11-05-2013 08:35 AM
  7. viper8315's Avatar
    You still don't get it. It wasn't a matter of "losing root", you shouldn't have applied the update in the first place with the modification in place...You need to undo it before applying updates...When you signed up for the soak test, if you actually read what you were clicking on, Motorola even warned you to unroot the phone before applying the update. Sorry to sound harsh, but honestly, just trying to help you out for the future so it doesn't happen again...
    KWKSLVR, perkdog65 and phathands like this.
    11-05-2013 08:45 AM
  8. goliatham's Avatar
    I absolutely understand that I should not have applied the update without unrooting. That said, others in the motorola private forums did unroot, and are experiencing the same issue. I'm not posting here looking for help or complaining about this. I was just trying to find out if others had the issue (should have done so in Moto's forums first) and to hopefully prevent someone else from running into the same problem.
    11-05-2013 08:56 AM
  9. perkdog65's Avatar
    Check out @bignadad's Tweet: https://twitter.com/bignadad/status/397718065124622336
    Sent from my XT1080 using AC Forums mobile app
    11-05-2013 08:58 AM
  10. 18t's Avatar
    there's a reason its called a soak test and not an official OTA. they are testing it to make sure it works perfectly with everyones phones. if it doesn't work on a non rooted phone, that just shows that their test is not ready for OTA yet.
    11-05-2013 09:03 AM
  11. atlas9171's Avatar
    I haven't seen any non-rooted phones experiencing this issue as of yet. Seems pretty safe to assume it's primarily a problem on rooted phones only, which is why they warned people to unroot before applying the update. Hopefully the rooted users who ignored the warning were smart enough to back up their phones first since it appears a reset is the only fix at this point.
    11-05-2013 09:36 AM
  12. SeigaGen's Avatar
    Not true. Moto explicitly stated that this will be the final software unless something pressing changes it.
    Having a rooted phone prior to the update, moto warned that the update may not apply if the phone is rooted. This wouldn't constitute as a pressing issue.
    11-05-2013 09:52 AM
  13. goliatham's Avatar
    Could be considered pressing, but it probably depends on the number impacted. They did say that we should be ok if we revert to stock prior to updating. Some have done so, but still have this issue.
    11-05-2013 10:25 AM
  14. goliatham's Avatar
    Interesting. Must not affect everyone. People experiencing issues may not have unrooted completely. (or not at all, like my dumb self)
    11-05-2013 10:28 AM
  15. atlas9171's Avatar
    My Maxx was rooted briefly, decided to go back to stock and didn't have any issues with the update. So I'm guessing it's like you said, problems with getting phone unrooted or not at all seems to be the issue.
    11-05-2013 10:37 AM
  16. 18t's Avatar
    like, say, doesnt work on all non rooted phones?!?!? again, there is a reason its a soak, to ensure all phones accept it (enter soak) before they push it to everyone, and to ensure the devices function correctly for a period of time afterwards. so yes, what i said is true.
    tdizzel likes this.
    11-05-2013 10:42 AM
  17. damnyankees's Avatar
    I'm thinking I'd like to unroot and go back to 100% stock. What method did you use? I rooted with PwnMyMoto and am thinking of using House of Moto to unroot. I'm just nervous and want to make sure I don't screw up my phone.
    SamuriHL likes this.
    11-05-2013 11:10 AM
  18. jfriend33's Avatar
    I did not take the survey for the soak test. Although I did register when I had my maxx hd!
    Sent from my XT1080m using Tapatalk
    11-05-2013 11:39 AM
  19. Casen's Avatar
    Your phone is probably having problems because the root/recovery method destroys the stock recovery.
    Have you tried and FXZ ..FZX.. umm.. Fastboot restore through RSD lite (sorry I forgot which acronym it was)
    Sent from my DROID MAXX via Tapatalk 4.
    11-05-2013 11:43 AM
  20. gamerman623's Avatar
    I'm experiencing the same issue and nothing is working. Don't know what to do here.
    Edit: HouseofMoto helped me out big time. I was able to fix my phone and keep all my data. It unrooted it, but a small price to pay for a functional phone. Best of luck.
    11-05-2013 11:47 AM
  21. shouldbmtnbikn's Avatar
    I unrooted by going the FXZ via RSDlite fastboot route. It sucked in that it completely wiped my phone (and that I had to reload everything that was not already backed up via cloud storage), but I was able to go into the soak test feeling well prepared and unlikely to encounter problems related to root.
    And fortunately, that has in fact been the case. Installed the update early this morning and all systems go ever since.
    11-05-2013 01:50 PM
  22. jfriend33's Avatar
    Please tell me even though it wasn't listed, but that the navigation button backlighting has been addressed?
    11-06-2013 09:34 AM
  23. 18t's Avatar
    where did you get the files from? did you use the moto x firmware? or is there a specific one for the droids? just rooted my phone by accident, didnt realize that a restart was going to root it after installing pwn and not running it.
    11-08-2013 10:30 AM
  24. doogald's Avatar
    The navigation lights go off when you are watching a Netflix movie. I've read the same is true for daydream mode (or whatever that is called.) I don't know about anything else.
    11-08-2013 01:04 PM
  25. goliatham's Avatar
    Unless it's a setting somewhere that I missed, it's not true for daydream. I had to download Capacative Buttons app (for root) to turn them off. Even that has them always off.
    11-08-2013 01:14 PM
40 12
  1. Samsung Galaxy Note 3 - Restart problem
    By benpob1 in forum Samsung Galaxy Note 3
    Last Post: 01-31-2014, 07:56 PM
  2. Galaxy Tab 10.1 3G - Question about rooting? help
    By David Santos2 in forum General Help and How To
    Last Post: 11-15-2013, 08:54 AM
  3. Replies: 7
    Last Post: 11-08-2013, 10:20 AM
  4. Folder structure on Nexus 5
    By 1adam in forum Google Nexus 5
    Last Post: 11-05-2013, 02:23 PM
  5. Anyone try Dolphin Browser on the N5 yet?
    By N4Newbie in forum Google Nexus 5
    Last Post: 11-05-2013, 08:03 AM
