Hi,
I've recently been having a problem sending pictures in my texts. The first couple months I had no problems, but that last month or so, 90% of the time I try it fails. It just shows a green arrow saying it's sending and then a couple hours later a red X appears and says the delivery failed. I'm using the texting program it came with. I did install Mighty Text, to text from my computer, and thought that might be the problem, so I uninstalled it. Unfortunately the problem still persists. Does anyone have any advice? Why was it working fine before? What other things do you think I might have downloaded that might be causing this problem?
Thanks!
Thanks!
