1. diamondphoenix's Avatar
    Hi all,
    I have a new (for me) Razr M, which I have paired with my Motorola H17 bluetooth. For some reason, each time I use the Bluetooth, my volume settings seem to change on their own. For example, I normally have the option to have sound on/off on my screen, with the vibrate option showing for sound off. When I use the bluetooth, the two options change to sound on/silent. Also, after each use of the bluetooth, I have to go back into my settings and manually reset the volume levels on my ringtones, notifications, etc.
    Can anyone give me any insight as to why this is happening, and if there is any way to stop it? It seems to be a recent occurrence, but I'm already over it.
    Thanks!
    08-17-2013 06:17 PM
  1. Best way to create note - save to flash - for view on any computer
    By Heather Fitzgerald in forum Acer Iconia A200
    Last Post: 08-18-2013, 01:42 AM
  2. Want to return to complete factory settings
    By Noel Pio Roda in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 08-17-2013, 04:45 PM
  3. Replies: 0
    Last Post: 08-17-2013, 04:44 PM
  4. Replies: 1
    Last Post: 08-17-2013, 03:23 PM
