I have found that Tasker will not let the phone sleep. I have disabled it and simply used Smart Actions which WILL let the phone sleep. This has dramatically increased battery life. I'm not getting the 2 days like some people, but my 4G coverage is poor in my house. I have implemented a smart action to disable Mobile Data when the WiFi is connected. This has helped as well.
I am noticing that sometimes the WiFi will sporadically connect/disconnect. I am running an enterprise WiFi solution in my house and not a Linksys or Netgear. It doesn't always happen, but it still bothersome. I like the fact that it is an 802.11an 40MHz solution which ROCKS!
[snip]...I am noticing that sometimes the WiFi will sporadically connect/disconnect. I am running an enterprise WiFi solution in my house and not a Linksys or Netgear. It doesn't always happen, but it still bothersome. I like the fact that it is an 802.11an 40MHz solution which ROCKS!
When I got my MaxxHD I waited for the battery to totally die before charging. I then charged to 100% and since then the battery life has been insane.
This past weekend I took it off the charger on Friday morning and didn't put it back on until Sunday night. I used the phone over the weekend and was surprised when it would barely drop after taxing it with music, downloads and video. When I finally put it on the charger Sunday my battery was at 15%.
Coming from a TBolt where I would have to keep a charger at hand, this is awesome. The battery life alone is enough to say I will keep this phone. Although, the more I use it the better I like it and I'm glad I picked it.
has anyone read what the manufacturer recommends for charging procedures?
You didn't need to drain the battery to get it's full effect. I never do this and my battery life is insane. Ni-Ion batteries had a memory for battery level that would decrease if you failed to do this. But Lithium-Ion does not suffer from this.
