Dreamliner330
If I am rooted with the JB leak. How do I do a factory reset that will restore any build.prop problems I may have created? BTW, recovery reset & cache wipe didn't work.
Thanks!
Thanks!
So how do I do this on a Mac? I see that Mac file there, but its a .7z file and neither I nor my computer seem to have a clue how to open it or what to do with it.
Thanks!
After running recovery the option I don't see the option to install jb from SD card. Any ideas?
May not be a Mac utility yet for the cmd prompts. You don't need to be rooted if you want jellybean or need to follow these steps if you just want to flash Jelly Bean leak. If you want to flash the Jelly Bean leak and you are on the newest OTA then you just need to download the update zip to your external SD card and boot into recovery and install through there.
So will I still get OTA updates (like the official JB) when it comes out with the leak installed on my non-rooted phone?
re this new method, I've followed the instructions up to the point where it says to follow the onscreen instructions. Running the Utility, it says press any key to continue. One I press a key the window closesand nothing else appears. where are the instructions or menu you're supposed to follow. Am I missing something?
What part are you on? Did you get to the part where you had to generate a bug report.
Sent from my DROID RAZR HD using Xparent ICS Tapatalk 2
I generated a bug report I think it said failed
At the initial screen after you run the Bat file, it said to continue hit any key. I did this and that window closed. no other screen or instructions popped up. How long does it take for the instructions or anything(part where you had to generate a bug report)
to pop up?
