Does anyone know if we will get the battery percentage indicator in the JB update?
Sent from my DROID RAZR MAXX HD using Tapatalk 2
Oh OK I see. As for a native %age. Nowhere to be found. There's only one ROM available right now. Which is a stock ROM. No percentage there. Obviously if I'm using the toggles app
Sent from my DROID RAZR HD
Yea, hopefully eventually there will be some decent ROM options and choices.
No need to root. Use power toggles. It will allow you to place a battery percentage in the notification bar. Also allows you to customize toggles in the notification p
