i have read conflicting reports about leaving the wifi on all the time or off to save battery life.
anyone with direct experience to know if it even makes a difference?
thanks
Leaving WiFi on all the time will use battery. The question is--does it make a difference? I don't think so. I've got1 day, 9 hr., 54 min. on my last charge, WiFi has been on 100% of the time, and has used 15% of my battery, but I have 30% battery remaining.
So to make the numbers easy to work with, let's say I've got 33 hours of use on this charge and 33% battery remaining. With similar usage my phone should run out of battery at 49.25 hours. (I would not let it get that far discharged, I'd probably plug out in at hour 46.)
This means that WiFi has used 15% of 49.25 of those hours, or 7.4 hours. So if I never turned on WiFi I would get 56.6 hours of battery life, instead of "only" 49 hours.
I say leave it on all the time. Not worrying about battery management is one of the nice things of having the monster battery in the Maxx HD.
I leave Bluetooth and GPS on all the time as well.
Sent from my Razr Maxx HD
