1. Joe378's Avatar
    For those who had a TB with extended battery, how does the Maxx compare? I know the Maxx is approx 3000 mAh and the TB was approx 2750 mAh. Is the Maxx battery much stronger than the TB extended battery?
    01-27-2012 10:18 AM
  2. tazcordo's Avatar
    No experience with the TB extended battery, but just the difference in weight and size is massively in favor of the Razr Maxx, not to mention the dual core and better screen. Could go on and on...
    01-27-2012 10:23 AM
  3. AndroidXTC's Avatar
    Thunderbolt with regular battery vs Maxx. The Maxx is lighter too. The Maxx has a case on it too!!!
    01-27-2012 10:40 AM
  4. tazcordo's Avatar
    Sorry to get off topic, but how do you like that case. Any trouble using the volume buttons?
    01-27-2012 11:04 AM
  5. AndroidXTC's Avatar
    Its good I like it. The volume and power buttons are cut out of this style so its no problem adjusting them. Its also good with the screen protector no lifting problems.
    01-27-2012 11:28 AM
  6. fatboy97's Avatar
    Maxx battery is actually 3300mAh battery.... I came from a stock battery on a TB... 7 hrs on battery today so far and I'm at 90% battery life... not that my battery use is the same as anyone else... it's just what I have for the first full day of testing.
    01-27-2012 12:12 PM
