1. biggerdjam's Avatar
    this is my second Razr Maxx. i returned the first one due to it having a faulty battery. Now this one is fine but there is one problem, when i slide my finger left and right, the screen is rough and is not as smooth as my previous Maxx. i really don't know how to explain this but seems no one has the same problem as me. i don't know what to do, i do not have a screen protector on and i starting to regret getting the Maxx also because of the constant hiccups and freezing on it( i already factory reset it 2 times). Can you guys help me?
    05-07-2012 04:18 PM
  2. mrcraft2u's Avatar
    I wonder if it's a defective screen protector... Have you tried it without the screen protector on? But then again...if you have already had to do 2 factory resets...sounds like you received another bad MAXX. I have had my MAXX a little over a month and I just love this phone. Knock on wood I haven't had the issues you are having. But if you can take this current MAXX back and get another one...hopefully you will get one that works right...then you will see just how awesome this phone really is. Good Luck!
    05-07-2012 05:09 PM
  3. biggerdjam's Avatar
    i dont have a screen protector on. Also it is past my 14 day return and Verizon has locked me in a contract and took my money
    05-07-2012 05:17 PM
  4. fatboy97's Avatar
    Suggest you use a cloth for cleaning glasses... that is all I use and it cleans off scuffs (figure prints and swipes). Most sunglass stores have them.
    05-07-2012 05:24 PM
  5. panerai7's Avatar
    I would start looking at my fingers first.
    Are they dirty, dry, crackly? Do you use too much lotion or maybe not enough? Do you have a lot of dead skin buildup on the tips of your fingers?
    Please post a picture of your fingers so we can rule out "user error"
    05-07-2012 05:47 PM
  6. biggerdjam's Avatar
    i wash my hands a lot with moisturizing soap. i also keep my phone in perfect condition my always wiping the screen with a microfiber cloth.
    05-07-2012 05:59 PM
  7. durango992007's Avatar
    Try making sure your fingers are very dry. I know that if I have been sweating a little bit that my fingers will stick and not slide like they are supposed to. Get a cloth, really dry your hands and see what happens.
    Sent from my DROID RAZR using Android Central Forums
    05-10-2012 06:45 PM
  8. SirGeorgeKillian's Avatar
    Car wax. It will only take a drop, and avoid the mic and speaker. You can actually rub it on with your finger and lightly buff out with a t shirt.
    05-10-2012 08:56 PM
