Is it just me of battery life has gotten way better?
Sent from my Droid Razr Maxx
Are you guys part of the soak tester or has the update started rolling.
Did anyone else notice that the screen quality is a bit different? On auto, it seeks to dim a bit more than before.
Sent from my DROID RAZR using Android Central Forums
I definitely notice an increase in battery life. Installed ICS this morning around 5AM, charged it to 100% and unplugged around 9AM. I have literally been using it all day with heavy, heavy use just exploring all the new features and it's only down to 65% as I type this. Normally, with this amount of use on Gingerbread, I'd be down to 40-50%.
Wow my phone is getting terrible battery life.
They you go
