What's a good battery widget for ICS?
I was using Circle Battery widget because it can show my battery level percentage in 1 number increments, unlike 10 number increments like a lot of the other widgets.
Unfortunately, the ability to view your battery stats from the widget no longer works.
I tried downloading other battery widgets, but they only had the ability to show my battery percentage in 10 number increments.
I'm looking for a good replacement.
Sent from my DROID RAZR using Tapatalk 2
