MrHost
Any reason you are running GB instead of ICS? Some changes were made going from none to the other.
Sent from my Xoom using Tapatalk 2
Well having that info would have saved me some time and trouble for sure as I didn't know the function of webtop , but had froze it at least eightor ine months ago so of course thought it to be some benign app not needed. Just goes to show, but listing all my frozen apps would have been to much. I've been an android user for the past two years and there's definitely a learning curve, but its all good and I've got things set where I want them again.We probably should have asked what you froze. Webtop is the specific app used to push through HDMI, so that mashes perfect sense. Glad you found it either way.
Sent from my DROID RAZR using Android Central Forums
What HDMI cable that came with the phone?!?!?!?!?!?!?!?Try rebooting the phone and hooking it up again. If that doesn't work, you could always try the old cache partition wipe:
How to Fix Droid RAZR and Droid RAZR MAXX Ice Cream Sandwich Issues
Also, are you using the HDMI cable that came with the phone?
