1. sugiebuns's Avatar
    Hi, im new here so please be gentle, lol. My droid Razr max HD is stuck on the Motorola dual core technology boot screen I know there are several threads about this but For my particular problem, haven't found anything that has worked. First of all when I unplug the phone from the charger it is totally unresponsive, while plugged into the charger I get the Motorola screen and it will show that the battery charging meter. I am able to get into the factory the android factory reset options but when I press factory reset it just goes back to the Motorola boot screen. I recently replaced battery but still getting the same results. I've also tried all manor of button combinations yet all that ever happens is the boot screen. Can anybody help?
    03-01-2013 04:00 PM
  2. durango992007's Avatar
    First things first, wrong forum, you want the Droid RAZR MAXX HD forum. Second, is your phone rooted? If not, this could just be a matter of calling Verizon and telling them what's going on and they should send you a replacement one. If you are rooted, there are ways to unbrick the phone, as long as, it is not to far gone.
    03-01-2013 04:17 PM
  3. sugiebuns's Avatar
    Thanks for the response Durango. Should I delete and post there? And yes....the phone is rooted. Would you be so kind as to tell me how to urn brick it, if possible?
    03-01-2013 06:43 PM
  4. durango992007's Avatar
    There is a sticky in the RAZR hd forum for rooting, you can ask there. I'm not exactly a pro on rooting but most of the time, from what I've read, you save a bricked phone.
    Sent from my DROID RAZR using Android Central Forums
    bradenfontaine likes this.
    03-01-2013 08:32 PM
  5. sugiebuns's Avatar
    I'll check it out. Thanks for the info, much appreciated!
    03-02-2013 07:14 PM
  1. I think it's bricked...
    By enviroag02 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 06-13-2011, 05:51 PM
  2. (Resolved)Possible brick, please help
    By 18annu18 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 04-11-2011, 11:03 AM
  3. Optimus V maybe BRICKED... please help
    By Lindo694eva in forum Virgin Mobile Optimus V
    Last Post: 03-04-2011, 10:48 PM
  4. Bricked????!! Please Help
    By evonotevil in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 01-04-2011, 01:21 PM
  5. Is my Hero half-bricked? Please HELP
    By klopinator in forum General Help and How To
    Last Post: 08-27-2010, 07:00 PM
