Data usage monitoring issue
RazrMaxx1345
81
Has anyone else noticed this? I am running the leaked 4.1.2 from Christmas and it works fine but check this out. My data usage says 1.14gb yet it is trying to day that Netflix has use 1.98gb? Based on what YouTube says too it looks like it is doubling data usage per app but registering the total correct.
(I know the total is correct because my Verizon app shows that number too. I will post a photo of that too once I edit out my phone number.)
I don't know if this is a Jelly Bean thing or a razor thing. Mine is Maxx BTW.....very weird nonetheless.
Sent from my DROID RAZR using Android Central Forums
The 1.98GB usage is for a month period. It shows that in the pic you have posted.
Are you suggesting that the apps don't follow the same schedule as what you set it up for? I understand that all of the data is for a month period but both the total and what I have the data usage set at is with my billing cycle.
Ignore if read it already. I see the dates now.
Sent from my Xoom using Android Central Forums
The difference is what data was used on WiFi. Data usage monitors both connections not just 4g/3g. When I look at my zoom my WiFi is monitored but I don't have mobile data on that. Looking at my maxx I can select to monitor WiFi too. If you look at data usage and hit menu does it give you option to monitor what you want. Mine does on ICS.
I am monitoring only mobile data there. Notice the tab is blue underlined. Wifi usage is the other tab...
If you click on the other tab is the information reflected differently?
The little note stating ,this is what your carrier used ,makes me think that.
Yea it is. It is actually on a totally different cycle too.
The info is totally. Different
Taylor Bag
