1LoudLS
Active member
I guess it really is as simple, if that is a feature that you "HAVE"to have, then this phone doesn't fit your needs. Time to just move along.
I've never heard of a smartphone that was close to being usable all day with heavy usage. Moderate usage, yes, but not heavy. The screens just can't be powered that long on those puny batteries, not to mention the extra grunt work required for the "heavy" usage.
Too many of you are using the non-removable battery as a deal breaker for this phone. The iPhone is in it's 5th generation and it hasn't had any significant problems now has it? Out of all the problems with the iPhone we've seen in the press and on TV I haven't see one thing about permanent battery being a problem. So if Apple can do it, I trust Motorola has engineered and tested it and passed it to work well before releasing such a great phone.
I never bought a spare or extended battery for my OG Droid that I've had 2 years now. I just bought a car charger and took my AC charger with me to work or if I'm going to be away from home for over a day. That's just me.
I will never again buy a phone that doesn't have a removable battery. It is one of the reasons I left the iPhone herd. Too bad, I was interested in the phone before I became aware of this issue.
It happened to people who got the 4g upgrade to their Xooms who then decided to flash older versions of android, and then flashing back to the sbf that Motorola originally released for 4g Xooms.
It worked until reboot, then they were stuck on the boot screen and holding the two buttons didn't do a damned thing. End result, they had to wait till the battery drained until they could fastboot a working image.
The moral to this story is, if you are gonna mess around with things that can necessitate a battery pull, and you're not willing to wait for the battery to drain, don't buy a phone with unremoveable battery.
Everybody else should be safe relying on the two button salute.
Well the Razr isn't for you.Nothing personal to anyone. But assurances from people on a forum does not give me a warm and fuzzy feeling. Software is software, and even on my laptop I had to pull a battery once to get it to reboot, then I had to reload all the software. A big pain, but at least in a few hours I had a laptop working again. And I might add, that I was told the eight second press of the on/off button triggered the BIOS to do the reset...well, it didn't work! And if I am not mistaken, BIOS is just software code written directly to the mother board ROM chipset.
My droid required a battery pull twice (maybe three times), otherwise, I would have had a black skinny brick.
I know quite a few people with iPhones and two have had to take their phones to the Apple store for a battery pull. Happened to one person once, the other twice. That may not be a problem if the Apple store is nearby. However, in my case, the nearest Verizon store is 115 miles away and this can be common for people living in the western states.
I understand this is not a common problem with any electronic device, but it can be a necessity and if it is, it sure is nice to pull a battery to solve some software glitch.
Don't misunderstand me, I love the Razr, figure it will be my retirement gift to myself and a chance to dump the X. But I sure would like to know if there is a way to pull the battery by removing some screws vs. having a brick in my hand. But looking at all the Razr photos, I see no screws to remove.
The thing with me is when a phone has a pro I want, need...I tend to overlook, live with the cons as long as it isnt a major con. Which is something anyone must do IMO: decide the cons you can live with and it will make your phone choice easier.
