Having the problem of the phone going from 4g to 3g to no g.. verizon is sending out software update for bionic. Anyone having this problem also?
No issue here at all 4G stays locked. I haven't noticed any fluctuations between the two. This is the best android device to date for me except the camera could be better.
Sent from my DROID RAZR using Tapatalk
Currently there is a setting you can change deep within your phones menu that helps with the hand shake between 3g and 4g. It will cause your data to drop out for a minute while switching between services, but will also keep you from having to reboot or flip on and off Airplane mode to get data back.
I'll be sticking with the razr as this upgrading every month out of contract is getting pricey. I love it, mainly due to size and weight. Anyway, this issue is not a Motorola only Issue. I had the problem on all 5 4g Phones I have owned. HTC, LG and Motorola. Everyone I know with the different 4g Phones has the same issue. So we are not alone. Motorola has a fix coming out this Month, and VZW is more than aware of the problem. If a rep tells you to reset your phone, tell em to piss off and research the issue a little better. Currently there is a setting you can change deep within your phones menu that helps with the hand shake between 3g and 4g. It will cause your data to drop out for a minute while switching between services, but will also keep you from having to reboot or flip on and off Airplane mode to get data back.
Yes it's true. I am having same issue with Thunderbolt. Must be a network issue.
