jmeyers278
also lithium based battery cells do not need to be discharged fully EVER!...DOD or depth of discharge is a big factor in how long a lithium battery lasts. The less DOD, the more charge cycles you will get out of the battery. Charge your phone whenever you can. At 100% DOD a lithium battery will last around 500 cycles. at 60% dod a lithium batter will last closer to 2,000 cycles. You do the math.
