1. Rich Coralli's Avatar
    I have been having better battery life on 4g only by disabling wifi. Any thoughts? Does wifi consume more juice?
    Sent from my DROID RAZR using Tapatalk
    11-18-2011 09:49 PM
  2. YourMobileGuru's Avatar
    Wifi uses less juice IF you are getting a strong consistent signal but if you keep loosing and regaining or it is always searching then it wastes a lot of battery.
    My advice is do what works better for you
    11-18-2011 10:11 PM
  3. thebrain73's Avatar
    I have also noticed better battery life with 4g over wifi. I get crazy good battery life by turning off 4g and wifi, and using 3g only.
    11-19-2011 06:32 AM
