1. Chipmunk's Avatar
    The website shows that this fits the DROID X and X2. This is almost wrong.
    Without a case, it barely fits. With a case. Not a chance. It is a good mount and would recommend it for anyone with a smaller device, but not large devices.
    So if you are looking for a car mount, probably not the one you want for your large device.
    If you have a small device. Definitely get it. For the price, its perfect.
    The construction seems decent enough for the price.
    06-13-2011 02:21 PM
  2. riot#AC's Avatar
    Although the iGrip universal window mount does fit our phones quite nicely.
    sent from my Cm7X2 using tapatalk
    02-01-2012 07:59 PM
