1. kajii's Avatar
    For those that have it, are you able to record while it is mounted?
    Interested in recording track footage and would like to avoid having to spend hundreds to do so.
    07-17-2010 12:06 PM
  2. Ender0715's Avatar
    havent tried to record while in car mount but it dosnt block the cam so there is no reason that it shouldnt...
    kajii likes this.
    07-17-2010 12:15 PM
  3. kajii's Avatar
    Perfect, thanks
    07-17-2010 12:26 PM
  4. problem0atique's Avatar
    I was wondering the same thing so i decided to try it out.
    07-17-2010 05:54 PM
  5. kajii's Avatar
    ^lol I just bought it about an hour ago and made my own vid as well. Very satisfied with it... I'll post a link once the Audioswap is done.
    07-17-2010 05:59 PM
