I have the bulky Verizon case, but what if I want to use the desk or car dock? Are any skins or snap on cases thin enough to work in the docks?
I got the verizon gps mount. It has a piece you remove to fit in a case. Might work with the verizon case. Funny thing is when you take off the extra piece to fit a case writing on the inside says for use with the droid shadow. X's code name and they never changed it.
Sent from my Rooted DROIDX using Tapatalk
