Help with Newb mistake
krusty46
23
I apparently botched rooting my Transformer (b60). I did manage to install Clockwork Recovery though.
So now it will no longer accept the official Asus firmware updates, not will it accept a custom ROM.
Anyone know how to fix this?
I did a factory reset, but same problem.
I have tried updating the firmware manually, tried renaming it update.zip and putting it in root on SD card.
Every time it either says update aborted or I get the triangle/exclamation point error message.
Thanks in advance
araelbenjie
