[ACS][FIX][CWM]Rotation lag fix for EF02
chris41g
75
63
Tested on EF02 with cwm 3.1.0.1
First flash the zip... it gives you about 8 seconds to lay the phone on a flat surface after hitting yes to flash the zip...
then some framework edits will need to be made....
\system\framework\framework1.jar.out\smali\android\view\WindowOrientationListener.smali
Code:
    .prologue
    .line 54
    const/4 v0, 0x3
needs to be changed to
Code:
    .prologue
    .line 54
    const/4 v0, 0x2
if you have a framework.jar that has been modified, make the edits, if you are stock there is a stock deodexed framework.jar edited..
EF02 Rotation Lag Fix
akbarramadhani12
