12-15-2011 04:07 PM
26 12
tools
  1. Pandaman's Avatar
    I ordered my Nuvi mount from eBay. Great find!
    I have an Epic 4G Touch and need some kind of mount for my car. How well did that Nuvi GPS mount fit? Are there any clearance issues when the phone is turned to the vertical/portrait position? Does it hit the windshield? If it is mounted on the dashboard instead of the windshield, can it be turned to the portrait position and plugged into the charger without any clearance problems? I ask because by the looks of the picture, it seems like it might cause the phone to hit when it is turned to portrait. Thanks for any help!
    12-15-2011 04:07 PM
26 12
