[MOD/FIX][GPS] Dark_Knight's_GPS_Fix
Status
Not open for further replies.
Dark_Knight2
Banned
Jun 24, 2012
1,716
1,432
Ive seen thread after thread after thread about how crappy the Epic Touch 4G GPS is. So this is for all the people who have this issue. Please bare in mind that if you live outside the Continent of North America this modification will do you no good.
How does this modification work? What is the cause of poor gps?
Ok. Everyone has there own opinion onto why gps is crappy. Need to look no further then our lovely stock ROM samsung has let us use. The gps.conf is only 244bytes of simple code. The line you want to pay attention to is SUPL_TYPE=supl.google.com. Google Supl root certs are total crap. This is where the issue lies. By changing this line to ?supl.sonyericsson.com? you vastly increase your gps lock time. This is the reason you never see any gps mods for sony ericsson devices. They dont need them. I also added some misc lines of code to increase accuracy within 50 meters or less.
THE GPS ISSUE IS ALL SOFTWARE. IT HAS VERY LITTLE TO DO WITH HARDWARE. DONT BELIEVE ME? FLASH THIS MOD :)
Directions and Requirements:
YOU MUST BE ROOTED
YOU MUST HAVE CUSTOM CWM RECOVERY OR UNLOCKED STOCK RECOVERY
MUST BE ON GINGERBREAD OR ICE CREAM SANDWICH
1.) Download Gps Fix
2.) Boot into Recovery
3.) Wipe cache and dalvik
4.) Flash Gps Fix
5.) Boot out of Recovery
6.) Turn on GPS, MAKE SURE YOU ARE OUTSIDE. IF YOU ARE INDOORS YOU GPS MOST LIKELY WONT WORK.
7.) Open Google Maps
8.) Enter A Location
9.) Open Navigation
10.) First lock can take up to 90 secs. Each lock after is 2-5 secs
11.) Be wowed by this mod :)
Download Link for Dark_Knight's_GPS_Fix: Dark Knights GPS Fix Download Here
STANDARD DISCLAIMER? I AM NOT OFFERING ANY GUARANTEES. FLASH THIS MOD AT YOU OWN RISK. IF YOUR PHONE BLOWS UP CAUSE YOU FLASHED THIS AND YOU BLAME ME I WILL LAUGH AT YOU. :cool:
Sychotik
77
5
Hey dies this come with the liquid ice rom? Cuz if so my GPS is working great..
Sent from my SPH-D710 using Android Central Forums
michaeljc70
210
5
Is "UNLOCKED STOCK RECOVERY" rooted or something else? I know I am rooted and didn't install another recovery, but don't know what unlocked stock recovery means,.
Dark_Knight2
Banned
Jun 24, 2012
1,716
1,432
Unlocked Stock Recovery is a Stock Samsung Recovery that has been unlocked to allow the flashing of unofficial updates.
Sent From A Rotary Phone
michaeljc70
210
5
I insatlled Clockwork Recovery. When I try to flash this, it shows a status bar that goes away really quickly and then I just see an android on the screen and an "!" in a triangle. It just sits there. I tried twice.
When I go back to the main screen, it says "E:signature verification failed"
I was on the latest everything if that matters.
Dark_Knight2
Banned
Jun 24, 2012
1,716
1,432
Sounds like your on the stock recovery...not CWM Recovery.
michaeljc70
210
5
Does this do anything if you are out of the USA?
Previously, I had cached maps for where I was going and could not got a lock anywhere w/o a data connection.
Dark_Knight2
Banned
Jun 24, 2012
1,716
1,432
Yes. My gps tweak will not work outside of the north american continent. I can however make you one for your continent :)
DEF3NDER
526
129
Recently flashed a rom and the GPS would not lock for some reason. Flashed this fix and works great now. Appreciate it.
michaeljc70
210
5
I think this is keeping me from getting the Sprint update installed. It failed on a system check. I had unrooted and restored stock recovery before trying to get the OTA update. Is there a way to remove this or is this not what is causing the problem?
Dark_Knight2
Banned
Jun 24, 2012
1,716
1,432
Yes this will cause the update to fail. I will make a zip to address it later.
DEF3NDER
526
129
Can't you just wipe your phone and Odin back to stock? Or did you do this and the GPS mod is still there?
Sent from...B*+ch, my $h*+ is custom!
Status
