1. Henry Hong's Avatar
    With this trend to remove the 3.5mm Audio Jack, I thought that music playback with the USB-C would remain consistent in music quality.
    However, by using the USB-C to 3.5mm converter provided with the Essential PH-1, I noticed significant issues in music playback.
    With sorts of white noise / static would be extremely audible only during quiet segments in the music, in particularly classical piano music.
    Does anybody know if this is an issue with the current analogue earphone I am using? (Requiring me to throw away all analogue earphones?)
    Any help would be much appreciated!
    11-08-2017 12:00 AM
  2. modifier's Avatar
    The adapter from Essential has a Cirrus Logic DAC chipset inside the USB-C end. In theory it should output clean sound. I listen to FLAC, WAV and MP3 files using custom IEMs and occasionally notice small amounts of static in the MP3 files, not the lossless.
    I typically listen using an external DAC/AMP combo since I've never been happy with SoC DACs used in phones ever since companies stopped using discreet Wolfson / Burr-Brown / Ti DACs.
    Have you tried listening to the same files via a different source to confirm that it's the phone and not noise in the files themselves?
    Also, what app are you using? What headphones, earbuds or IEMs are you using?
    11-08-2017 09:23 AM
  3. andrew_ackley's Avatar
    Could it be you have a bad adapter?
    11-08-2017 10:21 AM
  4. Mdbills484's Avatar
    used mine for the first time today and it was flawless. very clean and loud output.
    11-14-2017 06:40 AM
  5. joewoo's Avatar
    How would you rate the dac?
    11-14-2017 08:02 AM
  6. modifier's Avatar
    Short of digging out old BlackBerry and iPod devices with Ti/Burr-Brown/Wolfson DACs for a direct test with lossless audio files, I'd say it's comparable. I'm happy enough with it that I'd use it for portable use without hesitation.
    I use earbuds with a mic for phone calls and the DAC sounds great on both ends.
    Sensitive IEMs might benefit from an external DAC/amp unit. I have one pair of custom IEMs that don't play well with anything but a DAC/amp with 100% clean power output from the USB source. For that I use a Schiit Wyrd. Without it I get static/noise that doesn't show up otherwise. That's why it would help to know what headphones/earbuds/IEMs @Henry Hong is using since that could help point to his issue. It might be his headphones and not the USB-C to 3.5mm adapter.
    joewoo likes this.
    11-14-2017 10:36 AM
  7. calebisaac808's Avatar
    Yups- I just bought an Essential PH-1.. Turned on Soundcloud and the sound was crap. I was bummin.. Then I try Mixcloud.. Bumping properly?? Going to do more research when I'm off work...
    09-27-2018 04:17 PM
  1. Why is there a question mark symbol next to my WiFi icon on my Moto X Play?
    Last Post: 03-31-2018, 11:40 AM
  2. need help in display problem
    By Kannan Rr in forum Ask a Question
    Last Post: 11-12-2017, 01:11 AM
  3. How to change my lock screen photo on a ZTE for straight talk
    Last Post: 11-08-2017, 06:34 AM
  4. How to change my lock screen photo on a ZTE for straight talk
    Last Post: 11-07-2017, 10:41 PM
  5. USB-C Audio Output Clipping?
    By pappy35 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 11-07-2017, 10:01 PM
