1. vhl71's Avatar
    Hi
    When my essential phone's screen is off and after a few minutes, if i want to unlock the phone using fingerprint sensor, it has no response until i wake the screen by pressing the power button first.
    It doesn't work like this on pixel - even if the phone screen is off, when i press the fingerprint sensor it automatically unlocks the phone.
    Is there a way this could be changed on essential?
    11-30-2017 04:25 PM
  2. Stinger4321's Avatar
    Hi
    Mine doesn't do this.. it wakes up instantly with the fine print reader. Are you on latest firmware?
    11-30-2017 05:10 PM
  3. vhl71's Avatar
    yes - I've the latest firmware - leave the phone untouched for a 5-10mins and see whether it works
    For me, it works if it wakes up if i touch the fingerprint reader within a min after the screen goes blank. My setting is to lock the phone after 2 mins. So after that i have to press the power button first and then the fingerprint reader
    11-30-2017 05:19 PM
  4. shashankmittal's Avatar
    I have not seen that behavior on my phone. I am running the latest NMJ32F build.
    Do you see a message at the bottom - "Too many attempts, try again later"? When that message appears, the phone disables the FP reader until the screen is woken up by pressing the power button.
    11-30-2017 05:26 PM
  5. Stinger4321's Avatar
    Even with the too many attempts message the fp reader still wakes my phone but i need to enter pin to unlock
    11-30-2017 05:40 PM
  6. shashankmittal's Avatar
    Correct, it will prompt for a pin if that message is displayed, but with my phone FP reader doesn't wake up the phone after too many failed attempts. I have to use the power button.
    You should email Essential, they are pretty responsive with customer issues.
    11-30-2017 06:13 PM
  7. vhl71's Avatar
    I'm on NMI81C build. no further updates available for me
    When the screen is off, i don't get any response. I leave the phone on the desk for 5-10mis. When i pick up and try to use fingerprint scanner, no response at all until i press the power button.
    So this might be an issue with this build
    11-30-2017 06:28 PM
  8. Randy Ohio's Avatar
    I don't know if it will help, but in settings>gestures>lift to check phone, make sure that's active. When I pick my phone up that just make it come to life and the fingerprint reader usually works. Hope that works for you.
    11-30-2017 11:03 PM
  1. upgrading to v30 from g6?
    By Jazzamuffin in forum LG G6
    Last Post: 01-03-2018, 09:23 AM
  2. Phone not remembering WiFi passwords
    By Willum08 in forum Ask a Question
    Last Post: 12-01-2017, 03:08 AM
  3. HTC One M8, how to boot into android?
    By Detrx Aegis in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 12-01-2017, 12:33 AM
  4. My computer can't detect my phone after flashing boot
    By Marzipanwithbigdong in forum HTC One A9
    Last Post: 12-01-2017, 12:29 AM
  5. Replies: 1
    Last Post: 11-30-2017, 05:21 PM
