1. nikeballr29's Avatar
    Anyone know of a legit website that has charging cradles for cheap? I can't charge my EVO because my usb port went bad and I have to wait for a replacement, (which I am hoping is tomorrow)
    I've searched Google but I am not sure if the ones I have seen actually work with the EVO
    Thanks in advance guys!
    06-15-2010 02:04 AM
  2. Gekko's Avatar
    if the port is bad not sure a cradle will work. how did the port go bad? user error/damage?
    06-15-2010 04:45 AM
  3. 2CupsWithString's Avatar
    Believe it or not, a Sprint store will charge your phone for you if you have one local. In one case I was able to drop my phone for a charge, went out to lunch and came back and picked it up.
    06-15-2010 06:53 AM
  4. Giblet's Avatar
    Only a full service and repair center could charge his battery at this point. Since they have devices that can charge a battery outside of the phone.
    06-15-2010 07:48 AM
  5. Laxidasical's Avatar
    I can't find the cradle anywhere, can someone post a link (even though it won't solve the OP's problem)?
    06-15-2010 08:17 AM
  6. kudosmog's Avatar
    um..
    http://store.androidcentral.com/seid.../8A83A6730.htm
    Dunno if it's what you're looking for, but it should charge the battery out of the phone no?
    xorbe likes this.
    06-15-2010 09:56 AM
  7. nikeballr29's Avatar
    Thanks for the link. That's exactly what I was looking for. This should work for in the meantime. I have absolute no clue as to how my usb port went bad? This is when having a touchstone-like charger would come in very handy
    06-15-2010 05:01 PM
