1. Doc's Avatar
    I will be getting the EVO next month when I can change carriers and phone (iPhone) without getting hit with a termination fee.
    As most people are having battery issues, I would like to purchase an extended battery (seidio 3500mAh comes to mind). I would also like to buy a case that will fit over the whole phone when the battery is installed.
    I have not been able to find any case that can fit over the phone with a protruding battery like the seidio. Does anyone have any suggestions.
    Thanks,
    Doc
    07-09-2010 10:43 AM
  2. ArkAngel06's Avatar
    Not unless siedio decides to make one for it.
    07-09-2010 10:53 AM
  3. Doc's Avatar
    Guess I will have to go with an external battery/charger then so that I can use a case to protect the phone.
    Thanks
    07-09-2010 03:46 PM
  4. Doc's Avatar
    Seems like Seidio is making a case to fit an extended battery
    Innocase Snap for use with Innocell 3500mAh Extended Life Battery
    Doc
    07-12-2010 01:02 PM
