1. Jerry-O's Avatar
    So I have an EVO and a Jawbone ICON and my wife has an EVO and a plantronics something. This means I have 4 different style plugs in my wall that have micro usb ports on the other end. It there a 4 port USB hub that plugs into the wall that can charge all of my devices (Using a micro usb cable from the hub obvoiusly)? I know the EVO can be more sensitive to chargers than other phones, but if there are some good recomendations I will try them out and report my findings.
    07-16-2010 07:39 AM
  2. Jerry-O's Avatar
    I have decided on the powered hub below. 4 amp power adapter should be enough to power everything plus some.
    For $17 on amazon I figured it is worth a shot.I will post a review once I get it.
    Belkin Hi-Speed USB 2.0 7-Port Mobile Hub F5U701-BLK
    07-16-2010 01:16 PM
  3. spike9012's Avatar
    Just a warning, the ac charger included with the evo is a 1 Amp charger, the usb standard is only 500 mAmps, so you phone will charge very slowly (the same as charging it from a usb port on a computer)
    07-16-2010 03:04 PM
