1. tailsthecat3's Avatar
    http://store.androidcentral.com/htc-.../8A37A6698.htm
    will this battery work in my evo? and can i use the replacement battery door that comes with the sprint extended battery(for the kickstand accommodation)?
    Sprint - All Accessories
    thank you
    04-21-2011 08:38 PM
  2. kd0axs's Avatar
    Battery should work, don't know if it would work with the Sprint door.
    Why not just get a battery/cover together that is made for the EVO?
    http://store.androidcentral.com/seid.../8A37A7187.htm
    Also, I hate to direct business away from the AC Store since it supports the site, but their prices are WAY too high. You can get them much cheaper on Amazon.
    Sent from my PC36100 using Tapatalk
    04-22-2011 08:08 AM
  3. tailsthecat3's Avatar
    main reason is for me to use an htc branded oem extended battery.
    04-22-2011 03:16 PM
  4. Coke PharmD's Avatar
    How much larger is that battery in comparison to the stock battery size?
    05-15-2011 06:05 PM
  5. jnl813's Avatar
    I agree they are expensive as buying it at best buy I believe that online should be cheaper than actual stores since you have to wait for it. Just saying.
    07-26-2011 10:36 PM
