Just wondering if anyone's had a chance to swim with their device yet and give any feedback on accuracy, usefulness, etc?
Thx, J
Thx, J
Just swam with my gear fit 2 pro for the first time today. I set it to 50 meters and then swam 10 intervals and the watch said that I swam 10. I recommend getting the workout set up on the watch before you get in the pool. It was hard to work the device with it wet.
Thx, J
Tried the new Update from Samsung for the exercise section. Selected Swimming from the list. It told me it was set to 25m but to alter it to my pool length for better accuracy. Which I did, set in 1m increments to 50m, so a 30m pool is very do able. Swam 1700m and it read 1700m. The new display while exercising was very easy to read, though the auto scroll meant it was difficult to go on set intervals. Even so I think it was much better than the results I have obtained using Speedo On. Now if Samsung could get the Running Pace indication correct I might be good to go.
