1. melga7's Avatar
    I bought a used rooted LG G2X, has ICS 4.0.2.. My son took it off the charger and tried to unlock it to play some games, and after like 5 tries it locked up and said I have to log into my google account to unlock the phone. I've tried this with the correct username and password (verified from my computer) but it will not connect. I do not have a data plan, just use Wifi to access the internet, and I alway keep the wifi off to save batteries. So now that its locked, I think it can't access the internet to unlock the phone from google because the wifi is off, and I can't get it back on. I decided that I probably need to do a system reset, and have been told to hold down the power and volume down button to reset, but when I do that, it says "software update" and nothing happens...
    So I'm not sure what my next step is...Is there another way to do a system reset other than what I've been told? or another way to get the phone unlocked?
    I'm a novice with this type of thing...
    04-20-2013 01:15 PM
  1. Can't use my phone Need Help!!!
    By LegendaryDolphins in forum HTC EVO 4G LTE Rooting, Rom's, and Hacks
    Last Post: 01-07-2013, 10:28 PM
  2. Replies: 1
    Last Post: 10-23-2012, 09:00 PM
  3. Replies: 3
    Last Post: 09-30-2012, 12:53 PM
  4. Unlocked My Touch 3g HELP!!!
    By gtaryder08 in forum T-Mobile myTouch 3G
    Last Post: 12-09-2009, 02:44 PM
  5. I need to unlock my Tmobile G1... Help!!
    By saruth in forum The Android Central Lounge
    Last Post: 07-28-2009, 03:05 PM
