Rooting help plz
mike turner3
I have a 7" nobis android 4.4 kit kat tablet but some apps & games it says my tablet not compatible or something like that so I'd like to root it but no luck finding much about this tablet
That's probably because some apps are made for smart phones and wont work in tablets. I don't think rooting would fix it but try towelroot
it might looking for specifications required by the apps you are downloading..
like gpu, cpu, or os version..
you must know your device specifications and apps requirements.
thank you!
SBASF
