10-28-2013 06:55 AM
62 123
tools
  1. FaisDogg's Avatar
    Hey all,
    So sprint 3G service in my area is unusable, and there's no LTE. 3G speeds run between 10-100 kbps down. I was getting better speed while roaming, so I started force roaming 4 months ago, and sprint seem to not care. I have been using around 10gb data per month on average. Now I'm in a dilemma, as I've heard that sprint will terminate the contract due to data roaming, one of my lines is ready for an upgrade, and I'm nervous about upgrading and paying for a device if they will kick me out.
    Btw I have no problem in getting kicked out go with better carrier..
    Thank yall in advance!
    Sent from my HTC via Tapatalk!
    06-26-2013 08:26 PM
  2. Almeuit's Avatar
    From what I've heard yes. If you root your phone you can get an app called "roam control" (just Google it) and force roam. I am pretty sure if you keep roaming and using a good amount of data they will boot you.
    Sent from my Sprint HTC One using AC forums.
    06-27-2013 07:09 AM
  3. FaisDogg's Avatar
    That's what I've have been doing. I use about 10gb a month on Verizon, and their 3G speeds are 1.5-2.5 Mbps...
    06-27-2013 03:07 PM
  4. delta7's Avatar
    Keep on using it.
    Sent from my iPhone using Tapatalk 2
    06-27-2013 04:17 PM
  5. GiantJay's Avatar
    I don't know how you still have service but it clearly states if I remember correctly you get 500mb a month roaming and they aren't very lenient after that. It costs Sprint a lot of money when you do this and in turn all of us customers.
    Sent from my Sprint Galaxy S4 using Tapatalk 2
    06-29-2013 12:38 AM
  6. Csan508's Avatar
    Well on my plan it states unlimited data with roaming but I have a older plan though
    Sent from my EVO using Android Central Forums
    06-29-2013 02:09 PM
  7. Almeuit's Avatar
    You sure? Go log in online.. I bet it's changed. It has for all of us... If yours says "see terms" I can safely say you don't have unlimited roaming anymore (see below). They ensured to get rid of it.
    Attached Thumbnails Will Extensive Data Roaming cut me out of contract?-1372548961857.jpg
    06-29-2013 06:36 PM
  8. Csan508's Avatar
    Okay I will look at my
    06-30-2013 02:10 PM
  9. gollum18's Avatar
    Man you're so lucky to have unlimited 4g still. My mom just upgraded her phone to the s3 and they included a new 4g charge with a data cap. We still have the unlimited everything plan though, I guess it doesn't count the for 4g. Even though my 4g is still unlimited. They must be charging on the new plans.
    Sprint GS3 Running TN's Msg and Chubbs
    06-30-2013 05:31 PM
  10. FaisDogg's Avatar
    When I called sprint about the service issues several times, in response to the network tickets they came to conclusion that the network is congested in my area.
    Recently, about a couple of months ago, I called sprint about the roaming issue, and that my roaming speeds are way better than sprint network, the tech support representative said, "your plan allows you unlimited roaming, you will not be charged extra, so if roaming works for, go ahead and use it until network improves in your area under network vision"
    07-01-2013 01:58 AM
  11. cgardnervt's Avatar
    My understanding is that your allowed to roam up to 50% of your Sprint network usage.
    As in if you surf for let say 1gig then 500megs of that can be roaming. Or that was the rule when I had them a few years ago.
    07-01-2013 07:37 AM
  12. Almeuit's Avatar
    That doesn't sound right. They only cap business lines and hotspots. Your phones 3g and 4g should be unlimited.
    07-01-2013 08:27 AM
  13. jrsharp70's Avatar
    It's not congested. Sprint 3g is garbage. Verizon 3g is faster than sprint 4g in many cases. I couldn't open a website on sprint 3g for the last year.
    Call and ask about the data roaming. It should be unlimited. If so, burn it up like it's your job. Let Play Music stream overnight. Make them kick you off.
    Then go get verizon. It isn't significantly more expensive, and youll have coverage everywhere.
    07-01-2013 08:36 AM
  14. srkmagnus's Avatar
    Correct, data should be unlimited. There could be debate as to if they throttle or not. I beleive Sprint has gone on record to say they don't and this, along with unlimited data, has been a huge selling point for their network.
    Regarding the roaming, I don't think there is anything in writing that says if you roam X data per month you'll get the boot. It's probably up to Sprint and what they define exesive roaming to initiate cancelation of your contract. You'll be given fair warning if you do roam too much.
    07-01-2013 11:43 AM
  15. Almeuit's Avatar
    Most contracts never say will since they don't always but they do write it so they can cancel your service. The terms and conditions of use says this....
    Sprint may terminate service if off-network roaming usage in a month exceeds: (1) 400 min. or a majority of min.; or (2) 100 MB or a majority of KB. You can monitor usage online through My Account. Roaming is not available with single-band phones, or to customers who reside or whose primary use is outside an area covered by the Nationwide Sprint Network. Sprint may limit or terminate service if you move outside of the Sprint owned-network.
    So they can terminate if they want due to excess roam.
    07-01-2013 12:43 PM
  16. GiantJay's Avatar
    Off-network Roaming: The primary use of your Device must be for domestic purposes within the Sprint-owned network. Domestic means use in the 50 United States and U.S. Territories (except Guam). Sprint reserves the right, without notice, to deny, terminate, modify, disconnect or suspend service if off-network usage in a month exceeds: (1) voice: 800 min. or a majority of minutes; or (2) data: 300 megabytes or a majority of kilobytes. The display on your device may not always be on and will not indicate whether you will incur roaming charges. You can monitor usage online through My Account. Roaming is not available with single-band phones, or to customers who reside or whose primary use is outside an area covered by the Nationwide Sprint Network. Sprint may limit or terminate service if you move outside of the Sprint owned-network.
    Sent from my SPH-L720 using Tapatalk 4 Beta
    07-01-2013 10:06 PM
  17. FaisDogg's Avatar
    Got a call from Sprint Compliance department, told her all about service suckiness.
    Sent from my HTC using Tapatalk 2
    07-05-2013 10:53 AM
  18. Mikey47's Avatar
    And she said?
    07-05-2013 08:06 PM
  19. FaisDogg's Avatar
    And she said?
    She said the reason I'm calling is to help you with your service issues, and talk about ways you can manage data roaming. I told her sprint either needs to fix their service or not to call me to stop roaming. She said we're not going to limit or terminate your service, but we reserves the right to terminate the service.
    Me: I'm ok with you terminating my service as long as you give me enough time to go with someone who has internet for their smartphones.
    Her: Right now I just wanted to bring it to your attention, but if that situation arises, we give you at least a month to look for the service that suits your need. But we would you to continue to be sprint customer, but you have to understand that roaming costs Sprint a lot of money.
    07-07-2013 01:42 AM
  20. GiantJay's Avatar
    Yes it does which then gets handed over to all of us customers. Just pay your etf like a big boy, and be on your way.
    07-07-2013 04:57 AM
  21. FaisDogg's Avatar
    Yes, since they didn't offer me termination, I will have to pay EFT next weekend and move on. Their service is unusable in my area.
    Sent from my EVO using Tapatalk 2
    GiantJay likes this.
    07-07-2013 04:16 PM
  22. GiantJay's Avatar
    It shouldn't be too much money if you've been in the contract for a while. Whichever carrier you switch to utilize the 2 week refund period in the beginning to make sure they will give you good service where you are.
    07-07-2013 05:21 PM
  23. cgardnervt's Avatar
    At the same token if Sprint cant give him service then he should be able to just walk away. Why does Sprint get the choice to break the contract but the paying customer does not? Its an issue with all carriers to be honest. It needs to be fix. Even Verizon and att are plagued with the same process.
    07-08-2013 12:20 PM
  24. GiantJay's Avatar
    Because they signed a contract and got a phone on a discount. Do I really have to explain this. Otherwise people could sign up get a new phone, go roam and get kicked and keep the phone.
    07-08-2013 12:23 PM
  25. cgardnervt's Avatar
    For the fact its a rare issue for Sprint or any other carrier they could also hold the right to black list that phone from working anymore. There problem solved for everyone. Sprint doesn't need to pay any roaming fees and the customer can walk away if the service does not work.
    Plus with real life you never know where your moving. The carriers could also over load the network. So many variables could be considered on what path to take.
    07-08-2013 12:43 PM
62 123
  1. Transferring Data from Blackberry 9900 to HTC One
    By Niall Devlin in forum HTC One M7
    Last Post: 12-13-2013, 10:06 AM
  2. No data with Straight Talk T-Mo sim card. Help!
    By eddiesmiles in forum Google Nexus 4
    Last Post: 08-18-2013, 11:43 AM
  3. Replies: 4
    Last Post: 06-29-2013, 05:24 PM
  4. Screenshot without the volume bar in the middle of it?
    By toddnbrown in forum Google Nexus 7 Tablet (2012)
    Last Post: 06-27-2013, 08:25 PM
  5. Is data being used when...
    By mrtwohands in forum Verizon Galaxy S III
    Last Post: 06-26-2013, 12:28 PM
