1. EvilMonkey's Avatar
    I just switched to AT&T from Verizon yesterday. Seems to be ok, except I can't send or receive MMS with Verizon users. I've tried two contacts...and both the stock messaging app on my LG G3 and Go SMS Pro.
    In Go SMS I made sure the setting was to limit mms to 300k, which was what I was using on Verizon.
    Googled this issue 'mms at&t to Verizon' and seems to be somewhat common. Honestly, it's a deal breaker with at&t if it won't work.
    Also sent to a Sprint user but haven't heard back yet if they got it.
    Oh, and it works fine to my wife, also on AT&T.
    07-13-2014 07:51 AM
  2. EvilMonkey's Avatar
    Also, the messaging apps do say they sent it...so no error or anything
    07-13-2014 08:02 AM
  3. EvilMonkey's Avatar
    Just got off the phone with them. They said since we ported numbers it could take up to 72 hours for everything to work. So she said to give it till Tuesday.
    07-13-2014 02:40 PM
  4. Jaramie10's Avatar
    I had this issue when I switched from sprint to T-Mobile.
    07-13-2014 04:20 PM
  5. EvilMonkey's Avatar
    And? Did it take 72 hours or so or did you do something else?
    07-13-2014 04:43 PM
  6. Almeuit's Avatar
    It can take awhile. I'd give it a day or 2 and I bet it'll be back to normal.
    I've been on all 4 carriers... During the port issues happened with each phone.. They resolved usually after 24 hours.
    Sent from my T-Mobile Note 3 using AC Forums.
    07-13-2014 07:29 PM
  7. EvilMonkey's Avatar
    This has been a no-go for me. Findings so far (behaves the same on my LG G3 and my wife's Galaxy S5, so don't think it's a phone setting or anything)
    Can send and receive mms/picture messages from AT&T users.
    Can send to, but not receive from T-Mobile users.
    Cannot send or receive to/from Sprint or Verizon users.
    Could this be a CDMA (Verizon and Sprint) vs GSM (AT&T and T-Mobile) issue?
    Since I came from Verizon, could they be holding my number hostage in some fashion? That's probably grasping at straws.
    I'm just about ready to go back to Verizon...support has been less than helpful and this all worked fine on Verizon.
    07-18-2014 07:36 AM
  8. EvilMonkey's Avatar
    Decided to switch back to Verizon. Heading over today while I'm still in Best Buy's return window.
    07-20-2014 06:50 AM
  9. Almeuit's Avatar
    Just curious... Why did you switch to AT&T?
    07-20-2014 12:40 PM
  10. mallow1998's Avatar
    I have the same problem on a Nexus 5 using textra. I can send them but it will take the recipient a while to receive them and vice versa. Very annoying.
    07-20-2014 03:49 PM
  11. EvilMonkey's Avatar
    In all honesty, probably a case of 'grass is greener'
    07-20-2014 07:52 PM
  12. Jaramie10's Avatar
    It took 72 hours. I know I was really frustrated with it.
    07-21-2014 12:03 PM
  13. EvilMonkey's Avatar
    I waited from Saturday through the following Sunday (8 days) and i didn't correct itself. Switched back to Verizon and all is well again. Not sure what the issue was with AT&T but they weren't able to resolve it for me fast enough to stay within my cancellation window.
    07-21-2014 01:24 PM
  14. Almeuit's Avatar
    Don't blame you for going back.. I wouldn't of put up with that either! .
    07-21-2014 02:17 PM
  15. krisguy's Avatar
    Most of those problems involve issues with something called a local routing number, which is how contact with other carriers is handled. This is something that rarely happens, but if I ask tech support to check it, it usually takes care of it.
    BTW, I haven't heard of this happening in 2 years.
    Sent from my HTC One M7 on Tapatalk
    07-24-2014 03:01 AM
  1. Print from moto droid maxx
    Last Post: 09-03-2014, 01:38 AM
  2. Movies to Watch on The Plane
    By pwscott in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 07-14-2014, 08:27 PM
  3. View SMS message content after you get one from 2 different people?
    By theargonaut33 in forum Android Wear / Wear OS
    Last Post: 07-14-2014, 03:15 PM
  4. your nexus 7 production date and charging time and my first impressions
    By bitek in forum Google Nexus 7 Tablet (2013)
    Last Post: 07-13-2014, 11:29 PM
  5. mic issue
    Last Post: 07-13-2014, 08:59 AM
