Derek Faircloth2 New member Aug 26, 2015 1 0 0 Visit site Aug 19, 2016 #1 Why would AT&T remove the Note 7 gif maker features?! It was one of the new features talked about! Terrible move AT&T. Posted via the Android Central App
G gozirra Well-known member Apr 28, 2011 546 1 0 Visit site Aug 19, 2016 #2 You think that's bad? Verizon changed the code so it's 8 bit BMP files on ours. Just kidding, that does suck, sorry for your loss.
Almeuit Moderator Team Leader Moderator Apr 17, 2012 32,277 23 0 Visit site Aug 19, 2016 #3 Did they? I think someone said it does have it.
SpookDroid Ambassador Jul 14, 2011 19,290 539 113 Visit site Aug 19, 2016 #4 Are you sure they removed it? It should be under 'Smart Select', not under its own section... I can't say for sure since I'm using a T-Mobile version but I can't see why they'd remove something like that.
BearlyFloats Well-known member Dec 22, 2015 102 0 0 Visit site Aug 19, 2016 #5 This thread is FUD. The GIF maker is there.
