1. johnmcc0710's Avatar
    I am considering moving to Verizon and wondering if I unlock my S8 and S8+ with T-Mobile I could use those phones. I know the networks are very different.
    I did the Jump on Demand with T-Mobile and between the coverage and customer service I am not a happy camper.
    The other thing is to pay them off and sell them and get Verizon phones.
    Thank You
    05-26-2017 06:22 PM
  2. Iva_LadyDiCaprio98's Avatar
    I don't believe it would work with Verizon being that Verizon and Sprint have CDMA bands whereas T-Mobile, AT&T, StraightTalk, etc have GSM bands, so neither Verizon or Sprint could cross over to GSM and vice versa.
    05-26-2017 10:00 PM
  3. L0n3N1nja's Avatar
    That's outdated information to an extent. The iPhone and most Android phones sold globally have the radios for both now, my Verizon S7 functions just fine on Tmobile.
    The best thing to do is check with Verizon to see if you can use your T-Mobile phone.
    05-26-2017 10:11 PM
  4. cell adviser's Avatar
    yes think so but be ready topaymore i rather go cricket and they ofger 50 dollars to switch or keep tmo
    05-26-2017 11:05 PM
  5. johnmcc0710's Avatar
    Thanks, I will see what makes sense and talk to Verizon.
    05-27-2017 01:21 PM
  6. Iva_LadyDiCaprio98's Avatar
    Okay my mistake, Verizon has a way to work with GSM but GSM cannot work with CDMA. I know this because I work with phones for a living and many people buy GSM unlocked devices thinking it would work with Verizon when it doesn't.
    05-27-2017 01:31 PM
  7. johnmcc0710's Avatar
    I went to the T-Mobile store and the lady there told me once the phones are paid for I can request an unlock code and use them on another carrier.
    I then went to Verizon, he gentleman there said he wasn't sure so he put a Verizon sim card in and and gave the message the phone needs unlocked. He said get them unlocked and bring them in and try them see if both S8's work. If not I will sell them and buy Verizon phones.
    I am happy with that.
    05-27-2017 05:26 PM
  8. James Rogers2's Avatar
    T-Mobile phones will not work on Verizon.
    05-27-2017 08:18 PM
  9. Almeuit's Avatar
    Not correct.
    05-27-2017 08:33 PM
  10. dpham00's Avatar
    Not correct.
    AFAIK, The only T-Mobile branded phone that will work on Verizon is the iPhone.
    05-27-2017 08:41 PM
  11. Almeuit's Avatar
    If you insert a SIM it will connect up via LTE. It may not have CDMA so it won't be fully compatible but.. to say it won't work at all isn't right.
    05-27-2017 08:41 PM
  12. dpham00's Avatar
    Thank You
    You would have to either flash the unlocked software or Verizon software for it to work on Verizon. Beware that incorrect flashing can brick the phone.
    05-27-2017 08:44 PM
  13. dpham00's Avatar
    It depends on the device and perhaps your account or whatever. I haven't tried a T-Mobile phone but the att lg g2 wouldn't activate with any service with a Verizon sim, even in a strong band 4 area ( i can get 100 + mbps on band 4 alone here). Same as other various unlocked phones excluding phones designed to work on Verizon like the Nexus, pixel, moto g4 and the like.
    I have heard some where able to get limited service though... So it is possible
    05-27-2017 09:06 PM
  14. Almeuit's Avatar
    A LG G2.. come on. Obviously I mean relevant phones lol :P.
    05-27-2017 09:06 PM
  15. johnmcc0710's Avatar
    Thanks everyone, I will just sell the TMO phones and get Verizon phones and be safe.
    05-27-2017 09:10 PM
  16. dpham00's Avatar
    But i also tried more recent phones like the Honor 8, zenphone 2. No recent att or T-Mobile carrier phones
    05-27-2017 09:15 PM
  17. Almeuit's Avatar
    In theory it should work... And the op mentioned the S8. I could test this week at work with a buddies s8 if he has it unlocked if need be.
    05-27-2017 09:16 PM
  18. dpham00's Avatar
    Verizon doesn't have to allow a device on its network unless it has band 13. And conspicuously, phones not designed to work on Verizon's network don't have band 13, at least from what i have seen.
    05-27-2017 09:20 PM
  19. johnmcc0710's Avatar
    If you are able and do not mind testing it please do. It could help other people as well.
    05-28-2017 11:55 AM
  20. UDPGuy's Avatar
    Yes, CDMA wouldn't work for some phones. But you can use LTE only and a lot of phones have the CDMA radio in it as well
    05-28-2017 08:05 PM
  1. Changing carrier using S3
    By johnmcc0710 in forum Samsung Gear S3
    Last Post: 06-14-2017, 09:09 AM
  2. Why is my phone turning on and off
    Last Post: 05-26-2017, 07:50 PM
  3. How do o get stat icon off the top of my phone
    Last Post: 05-26-2017, 06:14 PM
  4. What is this large icon on my status bar?
    Last Post: 05-26-2017, 06:01 PM
  5. Replies: 0
    Last Post: 05-26-2017, 05:30 PM
