Dell Technologies Cyber Savings Event - Up to 45% off
  1. robert trujillo's Avatar
    I switched over to Verizon from AT&T
    I actually unlocked my AT&T Note 9 to be used on Verizon since I switch I've had nothing but signal issues and drop calls so I called Verizon they were glad to replace the device sending my friend had total mobile protection on his account but even after receiving the Verizon device I'm still having issues every time I run a speed test it says card 1 instead of Verizon LTE it'll give me the Tower I'm connected to but it didn't say Verizon LTE
    07-31-2019 06:35 PM
  2. mustang7757's Avatar
    So you have a Verizon model now whith same issue?
    07-31-2019 07:08 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Are you saying that Verizon replaced your AT&T Note9 with a Verizon Note9 for free? That's astonishing -- I would've thought that Verizon would tell you it's not their problem, since you brought some other phone to their network.
    What's the exact model number of the current phone you have?
    07-31-2019 11:03 PM
  4. robert trujillo's Avatar
    SM-N960UZBFVZW (512GB – Ocean Blue
    08-01-2019 06:25 AM
  5. robert trujillo's Avatar
    Yes this is correct and my friend let me borrow his pixel 2 and it worked find
    08-01-2019 06:28 AM
  6. B. Diddy's Avatar
    What are you using to run the speed test? "Card 1" implies the phone is dual-SIM (which wouldn't quite make sense if it's a Verizon variant), unless the app you're using to test your speed automatically says Card 1, even for single-SIM phones.
    08-01-2019 10:53 AM
  7. robert trujillo's Avatar
    I've used the Okla speed test and open signal also I've noticed LTE band 4 will not give me xlte anymore for some reason when it used to even with the unlock AT&T device any recommendations or help with be Great thank you so much
    08-01-2019 01:17 PM
  8. mustang7757's Avatar
    Can try in phone settings reset APN and network see how it works out ? You'll lose saved password for wifi with reset network.
    Edit : also try in safe mode if issue still persist.
    08-01-2019 01:31 PM
  9. B. Diddy's Avatar
    So is the phone dual-SIM? Remove the SIM tray and inspect it -- are there slots for two SIMs? See the image here: https://www.easyacc.com/media-center...im-or-microsd/
    08-01-2019 06:26 PM
  10. robert trujillo's Avatar
    I've tried everything from reset network settings airplane mode to factory data reset is there anyway I can edit the APN and the reason why I ask is because when I try to edit the APN it is greyed out the the phone is not a dual SIM phone at least I don't think so it is the US Verizon version
    08-01-2019 07:06 PM
  11. mustang7757's Avatar
    You can't edit , but you can add one
    08-01-2019 08:09 PM
  12. robert trujillo's Avatar
    How do I add the APN because it's completely grayed out
    08-01-2019 09:40 PM
  13. mustang7757's Avatar
    Right in upper right corner add buttonGalaxy Note 9 issue  Verizon Can anybody help me figure this out-screenshot_20190801-224542_settings.jpg
    08-01-2019 09:46 PM
  14. robert trujillo's Avatar
    Right in upper right corner add buttonClick image for larger version.
    Mine is greyed out
    Attached Thumbnails Galaxy Note 9 issue  Verizon Can anybody help me figure this out-2019_08_01_20.00.01.jpg
    08-01-2019 10:37 PM
  15. mustang7757's Avatar
    Mine is greyed out
    That's strange
    08-01-2019 10:49 PM
  16. mustang7757's Avatar
    When you transfer stuff to your new phone how did you go about it?
    08-01-2019 10:51 PM
  17. robert trujillo's Avatar
    Samsung Cloud and Google Drive backup
    08-01-2019 11:38 PM
  18. robert trujillo's Avatar
    08-02-2019 01:41 AM
  19. mustang7757's Avatar
    Yeah should be fine from there
    08-02-2019 08:21 AM
  20. mustang7757's Avatar
    I think you stop in by Verizon and talk with them
    08-02-2019 08:30 AM
  21. Droidlover1977's Avatar
    it will fix itself. it goes away with the newest security update pushed yesterday
    08-08-2019 08:31 PM
  1. How can i find download manager on my phone
    Last Post: 08-01-2019, 06:31 PM
  2. Phone apps can't access media?
    Last Post: 08-01-2019, 10:06 AM
  3. Locked out of my lgl 34c
    Last Post: 07-31-2019, 11:02 PM
  4. Note 10 Plus dummy model unboxing
    By Bla1ze in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 07-31-2019, 06:52 PM
  5. Where can I close my tabs on galaxy j5
    Last Post: 07-31-2019, 03:56 PM
