When I do a factory reset it does not erase all their are logs in my factory reset applied by hacker
Welcome to Android Central! I merged your threads, since they're both about your concerns about being hacked.
First, how do you know a family member hacked you?
Second, wouldn't a family member already know your date of birth? And if it's a close family member, they might already know your SSN in the first place.
Third, what logs are you referring to?
Fourth, are you a minor? If so, have you spoken to your parent or guardian about this? Or is it a parent or guardian who "hacked" your phone? Hopefully we're not conflating "hacking" with "parental supervision."
You would have to reflash the stock firmware.
oh that's insane
why???
Our phones today have our personal information today, and when someone is trying to get it without our notice, it's rather cruel.
If you still have access to your device, make sure there's no monitoring app installed (some parental control or something like that)
also, try changing your password or maybe block your device if that's possible
hope everything will end well and your device will be protected
