1. GUZZLR's Avatar
    I'm trying to add my gmail in Manage Accounts (tapping the plus sign) because I started having issues with it because it stated the unable to sign in error, so I deleted the account from my phone and wanted to add my gmail back in...it wont let me.
    I keep getting: "Unable to set up account, Authentication failed" error
    Here's what I've tried to correct.
    * Checked to make sure I have the correct password and gmail address
    * Gone into email app settings and cleared cash
    * Tried Manual setup using IMAP with port 465
    * Tried using my old gmail password
    * Tried updating phone, no updates available
    Nothing seems to work
    Samsung Note 3
    Version 5.0 Lollipop
    Thanks
    05-09-2020 08:12 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you using 2 factor authentication with your Google account?
    05-09-2020 09:56 AM
  3. mustang7757's Avatar
    You going run into more issues being on Android 5 it's too far behind .
    05-09-2020 01:21 PM
  4. GUZZLR's Avatar
    How do I find out if I'm using two factor authentication?
    Thanks for the help
    05-09-2020 05:59 PM
  5. GUZZLR's Avatar
    I just checked my two factor authentication in my Google acct. It is turned off.
    still wont let me add my gmail acct.
    Thanks for the help
    05-09-2020 06:08 PM
  6. B. Diddy's Avatar
    Are you just trying to add the email account to your email app, or are you in the system settings>Accounts menu, trying to add that Google account for the whole phone?
    If you're trying to add just the Gmail account to your email app, which email app are you using -- the stock Samsung Email app, or the actual Gmail app?
    05-09-2020 07:24 PM
  7. GUZZLR's Avatar
    I'm trying to add my gmail in the stock samsung email area, so it can be with the rest of my emails...all in one place. The actual gmail app works.
    Thanks for the help
    05-09-2020 09:05 PM
  8. B. Diddy's Avatar
    As mentioned by mustang7757, it might be due to how outdated your phone is. Try clearing both the app cache and data from the Email app in Settings>Apps.
    Does this happen on both wi-fi and mobile data?
    mustang7757 likes this.
    05-09-2020 09:10 PM
  1. My Honor 10 suddenly has a dead zone in the middle portion of the touch screen?
    Last Post: 05-10-2020, 08:35 AM
  2. My samsung s7 edge notifi ation led is not working. What should i do?
    Last Post: 05-09-2020, 01:20 PM
  3. Pop up with: this language is not supported
    By kelin84 in forum General Help and How To
    Last Post: 05-09-2020, 10:18 AM
  4. Purchased google music to music play on s8
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 05-09-2020, 09:57 AM
  5. Purchased google music to music play on s8
    Last Post: 05-09-2020, 06:25 AM
