1. Young and stupid's Avatar
    Screen blinks itself on and off while trying to use unless you keep a finger pressed on screen...problem started after falling in river with phone.any ideas on how to repair?
    05-17-2020 06:13 AM
  2. me just saying's Avatar
    if it fell into water, you need to get someone to look at it. there really is no way to tell what is going on without the phone in hand.
    Laura Knotek likes this.
    05-17-2020 06:37 AM
  3. mustang7757's Avatar
    Sounds like you'll need take it to repair center
    05-17-2020 09:46 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! See this: https://forums.androidcentral.com/am...e-got-wet.html
    Phones, like pretty much all electronics, really hate getting wet. There usually isn't anything else to suggest at this stage apart from completely replacing one or more components, or just replacing the phone. Since the phone still seems to work partially, make sure your important data is backed up or synced somewhere NOW, since the phone could completely fail without warning at any time.
    05-17-2020 12:59 PM
  1. Samsung s9 resetting by itself Need help!
    By Jay Hanson1 in forum General Help and How To
    Last Post: 05-22-2020, 12:40 AM
  2. Need help with s20+ G986U-1
    By ltrinityl in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 05-17-2020, 08:49 PM
  3. How can i fix the pop up unfortunately voice comand has stopped
    Last Post: 05-17-2020, 12:55 PM
  4. need help with new s20+
    By Ardtullaich in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 05-16-2020, 12:04 PM
  5. Samsung s9 resetting by itself Need help!
    By Jay Hanson1 in forum New to the Forums? Introduce Yourself Here!
    Last Post: 05-15-2020, 07:34 PM
