1. DWFII's Avatar
    I have two Samsungs--an S5 and and S6. Both had trial versions of Malwarebytes on them. Both trials have expired.
    Do I really need a virus scanner and what is a good one for android phones?
    06-02-2020 06:40 PM
  2. B. Diddy's Avatar
    For the most part, it's still quite difficult to get an actual virus on your phone, because malware requires you to manually accept the installation (which is why they try to fool you into thinking you're installing something legitimate). Use common sense:
    1. Avoid shady websites that deal with things like porn, gambling, and "free" (aka pirated) apps/music/movies.
    2. Never ever tap on a link that appears in a popup while browsing, especially if they're warning you that your phone is infected -- they're just trying to scare you into installing some bogus "antivirus" app that is probably malicious itself.
    3. Only install apps from well-established app sources like Google Play Store or Amazon Appstore. Read a bunch of app reviews before installing an app to look for any complaints about adware or suspected malware.
    4. Turn on Google Play Protect features in Settings>Google>Security (or in the Play Store settings). This allows Google to periodically scan your phone's apps to look for malware.
    5. Turn off "Unknown Sources" in Settings>Security (or in Special App Access on newer phones). This prevents any app that wasn't obtained from Google Play Store from being installed (which could include malicious apps that are inadvertently downloaded).
    That being said, if you still insist on installing antivirus, Malwarebytes is generally held to be one of the best and most trustworthy.
    Laura Knotek and Morty2264 like this.
    06-02-2020 06:45 PM
  3. mustang7757's Avatar
    I don't use any , I feel not worth it , can cause slow downs and other issues as some get administrator rights and can change system settings .
    Laura Knotek likes this.
    06-02-2020 08:04 PM
  4. customshopkv1's Avatar
    I use ESET Mobile Security, don't even notice it until I get a transparent notification of a scan. Also have ESET on all my computers.
    06-02-2020 08:39 PM
  5. Laura Knotek's Avatar
    I don't use antivirus on any of my Linux devices, and Android is a type of Linux. I don't install APKs from dodgy sites and don't visit dodgy sites. I haven't had any issues since I've been using any type of Linux on computers or phones.
    mustang7757 likes this.
    06-02-2020 09:40 PM
  6. DWFII's Avatar
    Thank you all.
    mustang7757 and B. Diddy like this.
    06-02-2020 10:27 PM
  7. mustang7757's Avatar
    Thank you all.
    I like B. Diddy post pretty much sums it up. Good luck !
    06-02-2020 10:31 PM
  1. How do remove the Chrome sponsor from my S8?
    Last Post: 06-02-2020, 08:07 PM
  2. Work Profile Call or Voice Chat Bug. Need help, please!
    By zzahkaboom24 in forum Samsung Galaxy Note 9
    Last Post: 06-02-2020, 07:42 PM
  3. How do I unblock data, I can't even make a call!?
    By melanikoko in forum Ask a Question
    Last Post: 06-02-2020, 05:20 PM
  4. How do I turn off vibration when receiving a notification?
    Last Post: 06-02-2020, 04:30 PM
  5. Replies: 1
    Last Post: 06-02-2020, 01:14 PM
