1. Helen95's Avatar
    Hi
    In my virus scan shell shows with an android type pic but not as a system app. It says low exposure but also has quite a lot of access eg SMS and location.
    It doesnt appear in my apps list via settings to do anything about it. Is this malware or nothing to worry about? If malware how do I remove? Thanks in advance. I'll try and add some SS
    06-03-2020 12:52 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I moved this from the Android Apps forum to the General Help forum since the former is intended for developers to promote their apps.
    Shell is a system app -- nothing to worry about. See this: https://en.wikipedia.org/wiki/Shell_(computing)
    Laura Knotek likes this.
    06-03-2020 01:08 PM
  3. Helen95's Avatar
    Hello and thank you! That's all a bit over my head, but thank you for the reassurance. Is it normal for it to access sms, and if you have the time to answer this, for what purpose? Thanks again!
    B. Diddy likes this.
    06-03-2020 01:11 PM
  4. B. Diddy's Avatar
    See @Rukbat's post here: https://forums.androidcentral.com/ge...-my-phone.html. It's basically a way for the user to access deeper basic system commands. Since it's the system we're talking about, it presumably has access to all parts of the system, including SMS.
    Helen95 and Laura Knotek like this.
    06-03-2020 01:21 PM
  1. Replies: 9
    Last Post: 07-03-2020, 04:16 PM
  2. SMS with desktop(W10)-need recommendations.
    By Saintor in forum General Help and How To
    Last Post: 06-18-2020, 08:56 PM
  3. Replies: 1
    Last Post: 06-03-2020, 01:43 PM
  4. Is "shell" malware? It has access to SMS, etc.
    By Helen95 in forum Android Apps
    Last Post: 06-03-2020, 12:52 PM
